2001 306 Squeaky Clutch Pedal
My clutch pedal has started to squeak whenever I depress or lift it. wondered if it's the clutch cable? As biting point isn't too high.
Hope someone can help, as the noise is a bit annoying.
Try removing the spring from the pedal and putting a bit if spray lube on the pivot pin Smile
Thanks I'll try that.
  Squeaky belt from somewhere? Nathan1305 13 7,176 07-03-2014, 09:57 AM
Last Post: Nathan1305
