Hard throttle.
Hard throttle.
Hi all,
Im planning on whipping the T/B off my rallye this weekend to give it a general clean and de-gunk and also to try and sort my idling issue, one thing i have noticed with the car is the throttle pedal is really stiff and quite hard to press.
Is this normal on a gti6 / rallye? I havent driven any others to compare it too!
Is there anything i can do to make it lighter? I would prefer a lighter / more responsive throttle pedal if i can.
Thanks in advance
Matt
Team Cyril
It's the cable, drying out inside. I sprayed lube in mine, worked it in, and felt 100 times better Smile just not wd40! As its shit
Thanks chap Smile
I use Wurth Ultra 2040, seems to do a better job all round than WD40 so it shall get a liberal dosage of this Tongue
Team Cyril
Get some spray grease in there and try an work it in Smile works a treat
I do have some thicker wurth stuff that i use so might give that a go also Smile
Thanks for the advice
Team Cyril
My throttle pedal in my 1.6 was stupidly stiff so held it up and dropped a load of engine oil down it.....
worked a treat!!
I soaked mine in veg oil. Would recommend you just buy a new cable lol
