Help please.... Before i burn it.
#31
White smoke often indicates timing too retarded. It's only partially combusting causing the white smoke.
thought so, is there any trick to getting these things timed properly, they seem to just be a pig
Its alive and running well Big Grin
now it seems clutch is slippping... peugeot life...
Good stuff sweeney, glad you got it sorted!
Put a td04 on it, itl move the torque up the rev range and save your clutch Wink
nah cant be arsed with that, its a daily hack so i'll just go easy until i can afford new one, its not too bad just when you hit it hard, on 130k so probably on orginal clutch
I put on a k03 turbo while i had turbo off, like the quick spool Wink
My car is on 190k on the original clutch. It started to slip when I had the gt15, td04 solved that and still got 170bhp Big Grin
interesting alright, must be the lower end torque, something to look into at some stage..
