Bosch pump question
Bosch pump question
If i was to swap my lucas pump over to a bosch do you need any other bits like throttle cable etc?
[Image: cornishmafia.jpg]
You can use the Lucas throttle cable with the bosch pump. Same with the bracket.
you need lines and injectors...Smile
Along with the pulley pulley nut and woodruff key
Team Doesn't own a 306
and possibly some leakoff pipe
Best change the timing belt, tensioner a and all other thing whilst your at it
  Slack in bosch pump? dt_ 14 3,467 21-10-2020, 03:41 AM
Last Post: dt_
  Bosch pump help for newbie PugRy 2 1,996 05-01-2020, 09:09 PM
Last Post: jamie182
  Bosch pump fuel screw broken Forby 0 1,492 12-03-2019, 06:47 PM
Last Post: Forby
