01-03-2014, 12:30 PM
If i was to swap my lucas pump over to a bosch do you need any other bits like throttle cable etc?
Bosch pump question
01-03-2014, 12:58 PM
You can use the Lucas throttle cable with the bosch pump. Same with the bracket.
01-03-2014, 02:19 PM
you need lines and injectors...
02-03-2014, 08:07 PM
and possibly some leakoff pipe
03-03-2014, 03:34 AM
Best change the timing belt, tensioner a and all other thing whilst your at it
Quote:(15:06:27) Toms306: Wd40d it and had a good tug, came straight off |
| Slack in bosch pump? | dt_ | 14 | 11,897 |
21-10-2020, 03:41 AM Last Post: dt_ |
| Bosch pump help for newbie | PugRy | 2 | 4,479 |
05-01-2020, 09:09 PM Last Post: jamie182 |
| Bosch pump fuel screw broken | Forby | 0 | 3,116 |
12-03-2019, 06:47 PM Last Post: Forby |
