It's a long shot, but the one on eBay doesn't have a ridged pipe it is smooth instead which isn't ideal so I was wondering if they are like that or it is just a generic item and anyone has got a genuine GT2052S oil return flange. Thanks.
Wanted: K14 Oil Return Flange
24-02-2014, 07:11 PM
You can adapt a standard t2 / k14 to fit
The bolt holes are just further apart on the gt20, so you will need to file the holes out on the t2 one to suit. Best part is if you've clocked it right it ends pointing in exactly the right direction.
24-02-2014, 11:18 PM
I used t2 oil drain didn't require any modding to further turbo had to do some bending to fit the engine tho.
| Wanted: Estate tow bar assembly - flange type | Poodle | 0 | 1,605 |
03-04-2016, 11:16 AM Last Post: Poodle |
| Wanted: Bosch fuel return banjo | 306pc | 3 | 2,737 |
01-04-2016, 06:02 AM Last Post: Piggy |
| Hdi injector return pipes | Josh_Quant | 3 | 2,358 |
02-01-2016, 06:57 PM Last Post: Josh_Quant |
