My passenger side rear wheel is bent, its like negative camber where the top of wheel is leaning inward. But the other side is straight. ANy ideas?
Bent wheel
22-02-2014, 07:37 PM
22-02-2014, 07:53 PM
Where could I get a rear axle? Ive had a mechanic look and he said its the rear axle aswelll
02-03-2014, 03:02 PM
Common fault. The bush at the top of the trailing arm has gone. It is easier to replace the whole axle but make sure you see it on the car before it is removed to make sure that's not gone either.
If the wheel is tilting in far enough to touch the body work it will acually fail the MoT. A bodge fix for this is to move the body work. Big hammer!
02-03-2014, 03:19 PM
(02-03-2014, 03:02 PM)tonytony Wrote: A bodge fix for this is to move the body work. Big hammer! Or use a wheel spacer?
02-03-2014, 08:07 PM
How much you willing to spend? As if the beam ..."shafts" are worn which they will be these can be replaced along with the four needle roller bearings and seals, if left to long the beam tube will become oval shaped! And then defo a complete beam will be needed
| is my top mount bent? | allye | 4 | 3,303 |
12-04-2017, 12:22 PM Last Post: allye |
| Bent | rocker8742 | 25 | 13,470 |
07-12-2012, 09:34 PM Last Post: rocker8742 |
![[Image: image_zps45f2003b.jpg]](http://i39.photobucket.com/albums/e174/austinmini-2008/image_zps45f2003b.jpg)
