Fuel leak
Fuel leak
I have a fuel leak I was just wondering.the common places for it to Leak the block is dry but the grenade doesn't stay hard any ideas?
You mean you have air ingress into the fuel lines???
Main places are:
Priming grenade
Leak-off pies and end cap
fuel filter housing lid
white cross on fuel filter housing
fuel filter housing base
Nah I.don't thingk I do I Just have shit mpg and fuel under my car, x
oh rite, well if it's not on the block it might be a corroded fuel line under the car??
Check the Double breasted Whippet flange behind the passengers side middle wheel.Most likely.
(21-02-2014, 07:02 PM)Danny Wideboy Wrote: Check the Double breasted Whippet flange behind the passengers side middle wheel.Most likely.
this +1
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
Hopefully the rain holds of for more than a few minutes tomorrow so I can look under the car
  Major fuel pump problems, air leak, head gasket? Dantheman1312 2 2,196 22-08-2016, 09:57 AM
Last Post: r3k1355
  Leak of Pipe Air Leak PaddyPug 5 2,873 18-09-2013, 08:31 AM
Last Post: PaddyPug
  sack off fixing IP leak, adding 12V fuel pump. fieldofrob 9 2,530 23-11-2012, 02:00 AM
Last Post: fieldofrob
