Battery clamp
Hi,
Have many of you guys replaced the battery clamps on your car?
The positive quick release ones on the estate are f*cked and I'm not sure whether to get some off a scrap car or buy some new universal ones?
What have you lot done?
Well mine is now in the boot...
But bolt on ones are much better...I dont like the clip on type at all
I'm the opposite, I like the standard quick release ones for ease of use.
M6 bolt and a couple of washers does the job just fine. lol
Had to sort mine
Link here
http://306oc.co.uk/forum/thread-13188-po...#pid277140
(20-02-2014, 10:04 PM)DeeTurbo Wrote: I'm the opposite, I like the standard quick release ones for ease of use.
But how often do you take the battery out!!?
Im happier knowing it wont come loose or cause connection issuee with decent terminals
(20-02-2014, 10:12 PM)WiNgNuTz Wrote: M6 bolt and a couple of washers does the job just fine. lol
How do you mean?
(20-02-2014, 10:14 PM)cully Wrote: Had to sort mine
Link here
WOW, now that's a bodge!
Very true and some good points. I think I might just be lazy.
[Image: DSCN8473_zpsd2188747.jpg]
Said crappy clamp.
I've tried bending it back into shape but it's still not the best.
Ahh, you mean the terminals....i thought you meant the clamp as in the thing that holds the battery still!
I'll get my coat. lol
Haha, yep.
I did put terminal first as to what I was referring to but the terminal is on the battery. I think I should have put battery cable clamp to avoid confusion.
I haven't had a problem with the positive clamp tbh, the ones I've had have been plenty strong enough.
Though the negative is always poor in my experience. Had to change it on 3 or 4 of my 306s! Just used the heavy duty one from ECP, does the job fine and isn't really any more hassle to remove.
Gonna have to change mine as my plastic clamp went flying out of anger :L still holds though
Team disASTOR? Itwasntme
  Flat battery/ can't open at to charge battery Aaron _d95 18 16,019 01-12-2013, 08:26 PM
Last Post: C2K
