Threads: 150
14
Car Model/Spec: 306 HDI
Ok guys need some serious help as my passenger side window is stuck down and its getting colder.
How hard is it to replace this?
Also, where does it lead to? i was thinking that maybe it all just goes straight into the fuse box, therefore would be easy to replace?
Any help earns you some serious declan love
306 HDI, soon to be XUD
Threads: 23
you dont need to replace it. just repair it. Got a soldering iron and some wire? Cut back the loom so you can see what you are doing and get cracking.
TEAM TRACK CAR + An E60 530d M-Sport for the daily
Threads: 150
14
the wires are broken deep into the plug though
Threads: 87
31
declantg Wrote:.......my passenger side window is stuck down and its getting colder.
Incorrect, summer is on its way - man up!
Threads: 150
14
But as soon as it rains im f*cked
Threads: 150
14
and if someone can steal my indicators they will have a field day with this!
Threads: 23
declantg Wrote:the wires are broken deep into the plug though
Surely you can cut back to big part of the plug. I had this on an old one of mine and managed it.
Threads: 9
19
Given 3 thank(s) in 1 post(s)
declantg Wrote:But as soon as it rains im f*cked
No, not f*cked, wet!
Now MTFU!
Dec, I reckon it'd be easier to cut a loom and plug from a scrap car then stick that on (i know it mean cutting the two good wires on your loom lol ) cos that window wire is broken too fsr down to solder I think.
Threads: 150
14
i was thinking about this, might go nab one from the scrapyard tomorrow, but how will i no which wire goes where?
colour lol!
Or a multimeter.....
Threads: 150
14
fingers crossed they are the same!
81
Threads: 150
14
might nip by scrappy on way home and rob one mate
81
declantg Wrote:fingers crossed they are the same!
go get one!
Threads: 150
14
i am
declantg Wrote:i am
Well get on with it then!
Threads: 150
14
tomorrow
declantg Wrote:tomorrow
Oh for f..... :roll:
Threads: 150
14
will have money and fuel tomorrow though P
declantg Wrote:will have money and fuel tomorrow though P
Lol fair enough............I'll have fuel and NO money tomorow lol...damn diesel prices!
Threads: 150
14
its just getting worse
Threads: 465
114
Car Model/Spec: Vauxhall
go to the scrappy and you will get one in a worse condition MTFU and get the soldering iorn out!
Threads: 92
43
You're going to trust peugeot used the same colour wires?
cully Wrote:go to the scrappy and you will get one in a worse condition MTFU and get the soldering iorn out!
But one of the wires has snapped right at the plug, how can you solder that one??
Threads: 177
its easy to replace the complete loom without cutting anything, and its french, the colour means nothing, all the wires are numbered
Threads: 150
14
how easy dan?
Car Model/Spec: 306 D Turbo
Bit of advice, when you do it don't cut the whole plug off in one go. I did this expecting to use the numbers but they had rubbed off! Now my c/l doesn't work at all! Fail! Cut and join 1 wire at a time so you don't loose track.
Threads: 177
Remove all the seats and rear carpet
remove the metal bracket both sides holding the dash in(has the bonnet catch leaver bolted to it)
unplug from the doors and pull the plugs into the car
if its a 4 door pull the grommet out from the door pillar and unplug the rear doors
On ph2 unplug the central locking unit under drivers seat
unplug the loom from behind the fuse box, white and possibly a blue one too
lift up the side of the fount carpet (both sides)and pull out the loom
You will see what i mean when you start pulling it out and just put it back in the same
Threads: 150
14
Cheers buddy
