1.9 NAD Fuel Pump 2 Stroke Oil
Any body know what pump was fiited to my phase 3 nad, just so i know if i can run sunflower oil.
Also anybody ran their car with a hint of 2 stroke oil
2 stroke oil helps lube the pump & clean the fuel system.
Its fine on any diesel.
but has anybody used it
yes i do and many others on here, it helps lube up the pump . . .Smile
2 stroke is ok in any derv, get pics up of your Fuel pump so we can see if it will run sunflower Oil or not Wink
Yes ive used it. Its fine.
[Image: v-R2mslxTr]
[Image: 83b3KFoQNC]
(17-02-2014, 03:37 PM)Mattcheese31 Wrote: helps lube up the pump . . .Smile
Matt would know; loves to keep his pump lubed.
images dont work for me?
[Image: 2014-02-17155634.jpg]
[Image: 2014-02-17155625-1.jpg]
That's a lucas pump so no good for veg unfortunately
balls but thanks
Ive got a NAD bosch pump in the shed,Lines as well. No use to me,only gave £20 for it. P.M me if you are interested. HTH.
Dont think the bosch pump fits the dw8 nad in the phase 3 ...only the early xud9 nad lump
My mate has a ph3 nad, dw8, with a bosch on it as standard, so sure you can find a replacement somewhere Smile
It does fit but you need a different front loom and relay. Some DW8s have Bosch pumps as standard.
  Bosch pump fuel screw broken Forby 0 3,206 12-03-2019, 06:47 PM
Last Post: Forby
  Cold start issue- fuel pump? Blaze Addict 3 3,963 20-01-2019, 11:10 AM
Last Post: Martin306
  Is immobiliser coded to fuel pump? Huddo 2 3,450 07-12-2018, 03:04 PM
Last Post: Ruan
