Auto aux tensioner removal
Hi all, was wondering if anyone knows how to replace an aux belt on a D turbo with air con? It has the auto tensioner and im not sure how to release the tension, also it's a bit if a tw@ to get to with the power steering pump in the way!
Cheers! Smile
I'm running a Xantia engine with an auto-tensioner.
IIRC there's a nut on it to hole it in place, I undid that and then found you could shove a 1/4" drive bar in this square hole to move it and release the tension.
  aux belt tensioner a/c model removal? help CJ_Derv 2 3,011 09-06-2013, 11:03 AM
Last Post: CJ_Derv
