Do phase 3 1.4 petrol shafts and hubs fit hdi?
Just curious as I'm breaking a petrol one and i need a hub
With the hubs there are to different ball joint sizes. One been 16mm and the other been 18mm. The early cars you will find normally come with 16mm hubs. The springs will sit differently due to the weight of both engines.
Nope. Got both a 1.4 and HDi...the shafts are substantially bigger and don't forget the 1.4 box is different to the BE type HDi box.
if its an ABS car the hubs will fit.
But does the drive shaft of a hdi fit through the centre of a 1.4 hub?
(17-02-2014, 11:58 PM)maguire1992 Wrote: But does the drive shaft of a hdi fit through the centre of a 1.4 hub?
Pretty sure it will mate yes.
  205 drive shafts Doseph 5 4,361 05-03-2017, 08:32 PM
Last Post: Doseph
  406 HUBS thethorne 45 24,713 30-11-2016, 09:13 AM
Last Post: Janne L
  Do BE drive shafts fit MA hubs Dum-Dum 3 2,596 13-06-2015, 11:38 PM
Last Post: Rippthrough
