08-04-2012, 02:52 PM
my car is dlin the same as the black pug above this
so..... oil leak and turbo failure.......
08-04-2012, 03:01 PM
sexystu1987 Wrote:my car is dlin the same as the black pug above this
On the 306 waiting list.
08-04-2012, 03:47 PM
no its really fast stil
08-04-2012, 03:50 PM
So you don't quite have a boost leak but your over fuelling. I take it you floor it then it smokes?
08-04-2012, 05:16 PM
yea if i go ova the 2000 revs it smokes like any think wat did udo to ur car to make it smoke like that? i just wanna know wat it i because its a lush car! how do i put a pict up of my car
08-04-2012, 05:29 PM
You can upload it as an attachment to the forum or upload to photo bucket and copy img code
As for that smoke. No smoke no poke That's how diesels generally work. The fuelling is matched to the pressure of the turbo when its on flow but anything up to that The turbo isn't matching the fuel. You have morea fuel so some comes out as smoke unburnt fuel
08-04-2012, 05:44 PM
yea but i dnt like it so how do i tune it dow a bit
08-04-2012, 05:46 PM
sexystu1987 Wrote:yea but i dnt like it so how do i tune it dow a bit turn the fuel down or pump the boost up... It's unburnt fuel as 4way said, so either burn it up or get rid of it
08-04-2012, 05:48 PM
sexystu1987 Wrote:yea but i dnt like it so how do i tune it dow a bitTurn the fuel down or the turbo up. Or best is both You will have to go back to standard to get no smoke. And will be much slower
08-04-2012, 05:52 PM
do u no were on the car u an turn it down mTe sorry to ask lol
08-04-2012, 05:54 PM
Yeah I do but your best of understanding it before you play with it. Have a look at guides
08-04-2012, 05:59 PM
ok sweet were wil i find the guides?
08-04-2012, 06:24 PM
<!-- l --><a class="postlink-local" href="http://www.306oc.co.uk/forum/viewtopic.php?f=31&t=158" onclick="window.open(this.href);return false;">viewtopic.php?f=31&t=158</a><!-- l -->
have a read through that
08-04-2012, 07:50 PM
Seriously, if its smoking like hell at anything over 2k then it isn't just overfueling, no way in hell! if it was tuned that badly it would smoke more below 2k than once the turbo is spooled up....................................................
08-04-2012, 07:57 PM
so wat do u think it cud be den? i really dnt have a clue an just wanna get it fixted
08-04-2012, 07:59 PM
Sounds like your massively overfueling. Some vids would be good and some specs? Pump specs? Turbo type? Tmic?
08-04-2012, 08:03 PM
sexystu1987 Wrote:so wat do u think it cud be den? i really dnt have a clue an just wanna get it fixted De ja vous? Umm boost leak. Don't ask this question again, I for one won't be replying.
08-04-2012, 08:04 PM
sexystu1987 Wrote:so wat do u think it cud be den? i really dnt have a clue an just wanna get it fixted Ummmmm.................maybe it could possibly be A BOOST LEAK just incase you missed it the last 20 times, this is getting f*cking ridiculous now! 4WayDiablo Wrote:Sounds like your massively overfueling. Some vids would be good and some specs? Pump specs? Turbo type? Tmic? As per my last post Phill, if it was "massively overfueling then it would smoke more before 2k than after once the turbo is spooled up!
08-04-2012, 08:05 PM
sexystu1987 Wrote:so wat do u think it cud be den? i really dnt have a clue an just wanna get it fixted Again, if you still running a top mount intercooler ( a radiator looking thing on top of your engine) check the pipe going into that, if thats fine OR you have a boost gauge and running a steady boost, have a fiddle with the pump READ THIS FOR PUMP INFORMATION AND DETAILS ON TURNING YOUR FUEL DOWN: ginge191 Wrote:http://www.306oc.co.uk/forum/viewtopic.php?f=31&t=158
08-04-2012, 08:08 PM
mark_airey Wrote:Yeah I know I'm just trying to figure this guy outsexystu1987 Wrote:so wat do u think it cud be den? i really dnt have a clue an just wanna get it fixted Maybe he doesn't just mat it from idle or something I really don't know mark haha My money is on a boost leak as per my first post but he still says its boosting 2 bar.I'm onlyguessing its on a standard turbo
08-04-2012, 08:09 PM
4WayDiablo Wrote:My money is on a boost leak as per my first post but he still says its boosting 2 bar.I'm onlyguessing its on a standard turbo this..
08-04-2012, 08:11 PM
Do you have a boost gauge fitted? What PSI/Bar are you hitting when flat out, (3rd/4th gear, uphill if poss)?
08-04-2012, 08:12 PM
I think he needs to put some facts down. We have not got a clue what setup he is running...
08-04-2012, 08:13 PM
londondan86 Wrote:Do you have a boost gauge fitted? What PSI/Bar are you hitting when flat out, (3rd/4th gear, uphill if poss)? also any noise in the engine bay, out of the ordinary on boost..
08-04-2012, 08:15 PM
4WayDiablo Wrote:I think he needs to put some facts down. We have not got a clue what setup he is running... Agreed. From the beginnig. What turbo/pump setup do you have? Is a boost gauge fitted, what is the reading? What mods have been done to it, if you dont know I would contact the seller/previous owner for more info as you really are a bit clueless at the mo.
ginge191 Wrote:4WayDiablo Wrote:My money is on a boost leak as per my first post but he still says its boosting 2 bar.I'm onlyguessing its on a standard turbo Can I suggest reading the thread properly then...........the previous owner said it was "tuned to 2bar" also in the first post he said it was fine on the drive home, and now its smoking above 2k, 2 bar is also 30PSI, it isn't, wasn't and won't make that on a lucas IMO! Ruan only managed 29psi on an 11 Bosch so go figure! Still think its overfueling? or maybe that is popped a boost hose off? |
HG failure? | Nathan1305 | 13 | 3,815 |
10-08-2014, 09:53 PM Last Post: Nathan1305 |
Peugeot 306 xrdt oil leak turbo | 306__xrdt | 5 | 1,529 |
18-07-2014, 10:17 PM Last Post: toseland |
Leak of Pipe Air Leak | PaddyPug | 5 | 2,871 |
18-09-2013, 08:31 AM Last Post: PaddyPug |
