Potential swap.. AVOGTZ coilovers
Hi guys, not been on here for a while so apologies.
I have AVO GTZ adjustable coilovers on my hdi (have posted pics in the past) and basically at the bottom of the N/S front spring it has cracked which is unfortunately an MOT failure...
All I want for the car now instead of 'high end' coilovers are some budget coilovers with good springs!
Would anyone be interested in a swap?? Apart from the N/S spring, they are in good condition surface wise (label still showing just!) and last time I adjusted them I was still able to do it by hand. Adjustable damping still appears to work fine.
What spring rate are they? As I have 4 sets of avo coilover springs that I don't need anymore which I can have if you want to keep the avo's
Do you have the rear dampers too?
I'll swap for a set of TA technix with uprated springs and a set of sub 60k estate rear shocks?
Smile 40mm lowering setup swap coilovers HDIkyle 2 2,042 31-08-2013, 07:53 PM
Last Post: td_dan
  For sale or swap. Ta technics coilovers kentiiboii 33 20,469 23-06-2013, 11:39 AM
Last Post: ginge191
