Threads: 10
Car Model/Spec: 306 HDI 2ltr stage one
Given 0 thank(s) in 0 post(s)
Hi guys,
Is there any special tools required to change the discs n pads on a hdi? Going to have a crack later it's just il be using someone's driveway & I'd like an idea on what tools to take with me cheers fellas
Threads: 226
24
Car Model/Spec: A3 TDi
Some kind of big grips to push the piston back, copper grease, breaker bar, wheel socket, selection of screwdrivers, socket set, wire brush... Probably more but thats all i can thing of for now.
Threads: 91
2
Car Model/Spec: BMW 330Ci/VW Up/205GTi/205Mi16
Given 5 thank(s) in 5 post(s)
Impact driver for the little torx screws holding the disc onto the hub flange (and the hammer for it).
Threads: 117
119
13mm, 14mm, 19mm, t30 torx, mole grips, pipe grips (to release handbrake cable), t-bar, ratchet, couple of extensions, wire brush, copper slip (ears and back of pads), moly grease (sliders), flat-bladed screwdriver (to clean pad slides and wind back rear pistons)... Think thats it.
Threads: 10
Thanks a lot guys trust my luck it's started to rain!! Good job I've got an impact driver 'cos I know them bolts can be a b*stard!!
Threads: 162
21
Car Model/Spec: 306 HDI Dturbo, Estate & GTI6
Given 23 thank(s) in 23 post(s)
A blow torch on the area sometimes helps I've found.
Are you doing the rears and fronts?
Threads: 10
Yes doing the front and rears bud
Threads: 465
114
Car Model/Spec: Vauxhall
Given 97 thank(s) in 92 post(s)
big flat bit of steal to wind back the piston for the rear
Threads: 10
I used a thick chisel to wind in rear brakes worked a treat. The bolts that hold the disc on, I think I counted three that weren't sheered off lol getting the rear pads back in was a pain but had a lot worse! Done all 4 in the pooring rain, got a mate to hold a big brolly over me in return for tea. Can't be bad thanks again for info guys much appreciated
