i know not every bosch pump have them but is it worth wiring it up ? and is it just a wire from the glow plug to make it work cheers
bosch cold start advance
03-02-2014, 07:13 PM
I have never wired it up, only used the cable from the thermostat housing, and never really had issues starting.
03-02-2014, 08:32 PM
It dose connect to the glow plugs, its just one wire, cant see why not to connect it
03-02-2014, 10:31 PM
Connected it up starts so easy now
03-02-2014, 11:15 PM
Can you show me a pic of the cable my bosch is shit to start? Wana see if mine has one
04-02-2014, 08:44 AM
It's the soliniod at the bottom of pump picture is above
04-02-2014, 11:34 AM
Dam mine doesn't have that were they not fitted to all bosch pumps?
04-02-2014, 12:54 PM
No, the ones with that solenoid have throttle compensated dynamic advance - they will back off the injection timing as you lift off the throttle and bump up the timing when you go on the throttle, the others have a fixed SOI curve in relation to engine speed.
04-02-2014, 06:48 PM
Like Ruan said I have always had them with but never wired 1 up
05-02-2014, 02:19 AM
Interesting, my d turbo is hard to start sometimes and only starts when bumped. It also completely stops when going around a sharp corner. Could this be related as I have not got this connected up. Btw running 11mm gov mod!
05-02-2014, 07:58 AM
(05-02-2014, 02:19 AM)johnnytsa Wrote: Interesting, my d turbo is hard to start sometimes and only starts when bumped. It also completely stops when going around a sharp corner. Could this be related as I have not got this connected up. Btw running 11mm gov mod! If your car stops when going round a sharp corner there's something serious wrong there!
05-02-2014, 09:43 AM
Could be something electrical shutting the solenoid, or a problem with the tank pickup..
06-02-2014, 12:38 PM
Mine used to cut out when there was a lot of air getting into the lines
07-02-2014, 03:33 AM
Yea I think it's something more serious like pump. I've tried searching for air in lines etc. car can start fine then suddenly after a drive it won't start or cuts out, only round a corner tho!
07-02-2014, 09:46 AM
There nothing in the pump that can move as you go round a corner. And if it works fine sometimes id guess your pump was fine.
07-02-2014, 02:36 PM
Yea that's true but it's very odd because it starts straight away with the slightest of bumps! I could literally push the car by myself and it would start but Won't go on key!
07-02-2014, 02:41 PM
Does it turn over? Have you checked for 12v at the stop solenoid wire? Any dodgy looking wiring near the near or under the bonnet?
08-02-2014, 07:16 AM
Yea turns over but won't fire until bumped! Yea I've tried bring live feed to solenoid but still needs bumped! Really has me puzzled!
08-02-2014, 12:12 PM
(03-02-2014, 10:31 PM)Teddy Wrote: Connected it up starts so easy now Is there any way to test if this is working? My 306 starts quickly sometimes and other times takes a fair bit of cranking. I know the plugs are working ok. Just wondering if this is intermittently working it could explain the starting issues. |
Cold start issue- fuel pump? | Blaze Addict | 3 | 1,819 |
20-01-2019, 11:10 AM Last Post: Martin306 |
Lucas Advance Switch | RAW | 8 | 3,137 |
30-03-2018, 07:15 PM Last Post: RAW |
406 semi ecu XUD9, lumpy/idling issues,advance woes | Piggy | 3 | 1,369 |
28-11-2016, 09:39 PM Last Post: Seb_Ryan |
