stage 2 clutch options
Hi all just wanted to know what clutch options are out there for stage 2 needs doing. Slipping abit now on stage 1. Sachs any good? Or has anyone got any links or other optiobs cheers all.
I swear we get 4 of these threads a week, i think theres helix which are expensive but good and they tell you what it will hold and its more than enough for stage 2, theres CG thats a bit unclear about, something about a berlingo clutch and if your gentle a standard valeo might well hold for a while.
What he said^ and use the search theres enough clutch threads.
Have you considered a 6 flywheel with an XUD clutch, works well.
cg 5 paddle here holding 278lbft easily.
It's all about the cg paddle. Cheapish, developed on my old 306 hdi with 358lbft and no slip!
JP
JP
(01-02-2014, 08:00 PM)jammapic Wrote: It's all about the cg paddle. Cheapish, developed on my old 306 hdi with 358lbft and no slip!
JP
Such mixed reviews about them, wouldnt/couldnt give me any kind of figure as to what it could hold, and wanted more money than helix.
Sorry guys didn't mean to rewrite the same thing as everyone else asks. I dont really want to be spending 300 odd quid on a clutch but in sure you can get a reasonable clutch for about 150?
definately not more than helix for the paddle, mine was £300 all in. for all three items too
if you want to go stage 2 you will basically have to marginally limit your torque or else quickly destroy the clutch.
They told me £450 and told me if i only changed the friction plate i wouldnt increase the torque it could take at all over standard. So i wasnt interested.
300 gets you the friction plate, the pressure plate and the bearing bud.
They must have not liked me then.
Ask for the non custom one
Anyone used them stage 2 panther clutch off ebay? 177 quid doesn't look to bad or isit a load of crap?
A few have bought them but dont think anyone actually used them. The clutch is probably the one thing on a hdi that you need to spend the money on.
Okay mate guys no problem thankyou.
I did realise that it would be the bit I had to pay a fair amount for
Imo Sachs or Helix are the way to go, they're both well proven and as a rule you get what you pay for.
Incidentally, Jonny had his sub-10k CG paddle clutch out of the car this weekend and there's not much meat left on it. Confused
There never is much meat on a paddle clutch, the wear rate is sooo slow ud be surprised.
I read into this and it is infact normal
Helix seem to be the most proven, CG I had problems, and I've just fitted a black diamond kevalr fast road clutch which I have to say drives very nicely, although it is still slipping a tiny bit but I've not had a chance to bed it in fully yet, apparently it takes more than 500 miles and I'm supposed to be nice to it during that period?
It depends if you want drive ability or if you want an all out track car that rips your neck off as soon as you let the clutch up a little bit. Personally I'd rather have a bit less torque and a clutch that I can drive in traffic with. Obviously there is also the D-turbo clutch conversion with the GTI 6 flywheel, not sure how good those are though...?
I use the cg day in day out in traffic , as I travel peak times 17 mile to uni (45 minutes in traffic or more) and the same on the way home at 5 o clock, the clutch didnt need bedding in either which was great for me, no slippage at all.
I think they done a bad bunch for 306's in their earlier days but the vag fellas have gave them.good reviews and I cant really fault them lol.
Helix are proven as you say, but end up being costly after buying all three bits seperately
Yes that's the problem, the Helix clutches are so expensive.
We have a full paddle in the 1.4 HDI which I don't enjoy driving, and the dual friction plate (half paddle half normal) in the 2.0 with a heavy stage 2 and it slips still, although if you get it nice and hot it seems to hold better but can still slip. That dual plate is a lot nicer to drive though.
The 1.4 clutch rattles and makes a horrible noise on idle until the clutch is dipped, squeaks sometimes when pulling away too, their customer support didn't seem too interested on either of the issues when I contacted them which is why I thought I would try someone else.
It's a shame helix don't make anything for the 1.6, they told me it's at the bottom of their to do list too because they have Ferraris etc to make them for and obviously they will make a load of money out of that!
Yeah understandable on the money side of things.
Strange that it rattles, did you ring them or email? I found on the phone they didnt seem too impressive but were rather helpful through email.
I assume its cause they get a load of calls on the phone that come to nothing or the likes.
And was the rattle there from tbe start or did it come on after some use? Sounds like a release bearing hope mine doesnt end up this way
It wasn't there immediately I don't think, more like a couple of weeks. I think we emailed about another query and mentioned this and they ignored it. Most likely the bearing though as you said because it goes when you put pressure on it, either way we couldn't really be bothered to get the thing out again for a rattle (and it's my brothers car) so we kind of just left it, plus I don't think there is an alternative uprated clutch for that one.
For the price and for track car applications here you can get it nice and hot they are great clutches, just not for every day road use in my opinion, it depends on how fussy you are. After having a poly urethane engine mount vibrate my car to pieces for 6 months I decided to go fo the comfort option in all future upgrades!
Lol poly bushed engine mounts, no thankssss!
I find it gets more snatchy/grabby as it heats up, but it takes all the abuse I can throw at it so far lol!
Im just a power whore so couldn't have the risk of it slipping lol
McGlynn, is yours a sprung paddle clutch? Iirc it's normal for the unsprung ones to rattle, they're not designed for road use after all.
Indeed it is, very good point! Poor transmission if thats the case lol
Ive disided to go for the cg dual friction clutch kit so will let you know how I get on sounds a good set up so will see.
You dont need the dual friction one its over kill unless you plan to severely tune this (stage 3+)
Yeh I know but id rather be safe than sorry.
  Best clutch for stage 2 L16rye 4 4,554 15-11-2016, 06:36 PM
  Clutch kit Stage 2 ? MrBigMac 54 28,933 28-08-2015, 06:30 PM
Last Post: ct-hdi
  Stage 2 Clutch Chris HDI 15 9,303 23-08-2015, 08:28 PM
Last Post: ct-hdi
