HDI front brake pads
On euro car parts there are several pads available which all appear different to look at. I have a 2000 V reg HDI. Do I require pads without a wear sensor for the Lucas caliper?
You should need the ones with the sensor but you will need to cut the cables off when fitting.
These are the ones you should need.
http://www.eurocarparts.com/ecp/c/Peugeo...72d&000036
I don't think I have wear sensors, but is it a Lucas caliper on my HDI?
They're Lucas on mine to but it takes the pads that have the sensors you just have to cut the wires off as there are no plugs for the on the car.
  New Disks and Pads - Front & Rear Recommendations MisterGTR 6 4,067 10-09-2016, 08:15 AM
Last Post: cully
  Best brake fluid and pads? JTaylor2005 19 11,216 19-08-2016, 08:09 PM
Last Post: Pgtips
  Disconnecting rear brake lines at the front Iaitoo 21 10,897 04-06-2016, 08:22 AM
Last Post: pug306driver
