400hp 1.5 3 cylinder
#31
I've never had a car that used anywhere near that amount of oil, worst was my Golf using about a litre in 5k but that was on 170k and blue smoked like f*ck...
(29-01-2014, 09:20 PM)Ruan Wrote: And you couldn't hardly say they have "torque off idle"...
That RX-8 we had would piss all over any 2 litre petrol for low down torque.
[Image: 625d1315630388-rx-8-gearing-ratios-rx-8-...curves-jpg]
Well, that looks like about 100lb.ft off idle rising to about 160lb.ft at peak power.
[Image: 206-GTI-180-back-to-back.jpg]
That's a GTi180 - looks to be making about the same torque at about 2500rpm as the more powerful rotary.
But to be honest - this is the reality:
[Image: rx-8torque.jpg]
Yeah they dont have much torque to talk of
But wring its neck and you wont stop smiling
Totally - I'd f*cking adore one.
They sound like a strimmer, require lots of sympathy, but they are epic.
They do sound epic. Fact is they're a novelty and nothing more, I'm surprised they haven't caught on more where size and weight is an issue, like Caterhams...
Or a 13B powered bike?!?! OMG!!!
Think about what generates hp, it's torque over tiem.
So, lots of rpms and torque which is meh, gives high hp output. That's why people bang on about VTEC as well, it genuinely has no torque but the hp figure is good.
Torque is what gives you acceleration not hp.
So you need to rev feck out of rotary cos it got no torks. So Mazda fit short gears, so it revs faster which is a torque multiplier.
All in all, I'm just talking shit because I don't like rotary Tongue
(29-01-2014, 10:02 PM)THE_Liam Wrote: They do sound epic. Fact is they're a novelty and nothing more, I'm surprised they haven't caught on more where size and weight is an issue, like Caterhams...
I'm not, look at the hayabusa engines. 1300cc, and about 180bhp and 150lb/ft and weigh f*ck all
My bottom are they 150lb.ft!
100lb.ft barely.
Skin and rice pudding springs to mind!
[Image: hayabusa_99_dyno_1005.gif]
95lb.ft.
And a Hayabusa engine is considered pretty torquey!!!
Ruan, my bad
The older busa is 173bhp and just shy of 100lb/ft
the newer busa is 197bhp and just over 100lb/ft
Still with the PTW of the engine itself its a far better option in a bike than a 13B
(29-01-2014, 10:10 PM)Martin306 Wrote: Torque is what gives you acceleration not hp.
This bit.
(29-01-2014, 10:10 PM)Martin306 Wrote: All in all, I'm just talking shit because I don't like rotary Tongue
Confirms this bit.
(29-01-2014, 11:43 PM)Dum-Dum Wrote: Ruan, my bad
zx-14 will make over 120lbft with an exhaust and remap...
But f*ck it all, you want this:
http://www.holeshot-racing.co.uk/images/...121124.pdf
just think in 10 years time what the engine tech will be like, compare a 1.8 from the 70s to a 1.8 now. The 70s 1.8 was like a 1.4 power wise of the 90s!
I always tend to use the Constantly Very Harsh as an example. 132bhp from a turbocharged 1.6 is crap.
They did do a rotarg engined motorbike ninja
(30-01-2014, 12:46 PM)Piggy Wrote: They did do a rotarg engined motorbike ninja
Norton? That's the only one I know of. I more meant the fact that a 13B would easily fit in a mid-sized bike. The Norton rotary was shit apparently.
Mazda did one...
wanted to race it too, but too many arguments over what actuall capacity it was, so couldnt get in any races!
This bit.
Confirms this bit.
So uhh, I don't understand what is shit in that statement I made? Tongue
Torque is what provides you with acceleration. Engines naturally produce torque, not hp. The "stroke" of a rotary is small, it's momentum is low therefore it has low torque.
Good night! Sleepy
(30-01-2014, 02:59 PM)Piggy Wrote: Mazda did one...
I thought of another as well, Suzuki RE5.
(30-01-2014, 12:59 AM)procta Wrote: just think in 10 years time what the engine tech will be like, compare a 1.8 from the 70s to a 1.8 now. The 70s 1.8 was like a 1.4 power wise of the 90s!
In 10 years I reckon there'll be no more 1.8s coming out in new road cars. Wink
I can see the conversations now... "Do you remember back in the 2000s, when we were driving 2 litre diesels with only 90bhp and only getting 50mpg....now the 1.0TFSi does 80mpg and has 140bhp..." lol
That said, petrol will probably be over £3 a litre.... Confused
(30-01-2014, 07:21 PM)Martin306 Wrote: So uhh, I don't understand what is shit in that statement I made? Tongue
Good night! Sleepy
Wheel torque provides acceleration.
Wheel torque for any given speed is directly related to engine power. Not engine torque.
As for the stroke of a rotary being small meaning it makes low torque, that's actually pretty wrong, the eccentric shaft is geared up by 3x compared to the rotors, the rotors are actually making 3x the torque force you see at the end of the eccentric shaft - if it could work on a straight 1:1 shaft you'd see nearly 500lbft, albeit with a 3krpm limit...
Good night! Sleepy
Surely the same goes for a conventional piston engine, if you increased the crank throw you'd see much higher torque levels?
Hmm, or is that just because you're gearing it up rather...
I can't work it out, but f*ck it.
Yes I do want a V8 boosted 'busa engine.
Ripp, just face it. Rotary engines are shit Tongue otherwise everyone would be using them.
(31-01-2014, 05:32 PM)Martin306 Wrote: Ripp, just face it. Rotary engines are shit Tongue otherwise everyone would be using them.
Not shit in every way, just some ways. The way they rev is brilliant and the smoothness is amazing, not to mention the sound.
Diesel engines are shit, people still use those.
Ruan, it's just because you're gearing it up, if you changed the stroke on a normal engine that's not the same thing, and still wouldn't have the same effect.
The power density of the rotary is fantastic, so is the breadth of the torque curve on the modern ones.
[video=youtube] https://www.youtube.com/watch?v=8LSOaWNOfEQ[/video]
Sound epic don't they Wink
If you want smoothness, just add more cylinders. Also, the more cylinders you have the better the noise.
Diesel is full of win! Runs on anything, they're not fussy.
Even a V12 isn't as smooth as a good Wankel...
(31-01-2014, 11:20 PM)THE_Liam Wrote: Even a V12 isn't as smooth as a good Wankel...
What about 18 or even 28 cylinders?
I am being silly now btw, but engines that size do exist.
I've seen V16s, there was an old Cadillac V16 at the Lakeland museum, would love to have a go.
(31-01-2014, 06:29 PM)Martin306 Wrote: Diesel is full of win! Runs on anything, they're not fussy.
If you want something that runs on anything, it's hard to look past a nice jet turbine...
