306 1.9 TD DTurbo XUD9 engine replace questions
Hello all.
Im replacing my 306 1.9 TD DTurbo XUD9 engine from another car.
Wheather its a good idea to replace what bits to whilst engine is out?
Timing Belt?
Tensioner?
Waterpump?
Clutch Kit?
Clutch Cable?
Anything else?
Thanks
Sam
I'd be tempted to do the headgasket if you havent seen it running.
As tom said, also id put a new cambelt and tensioners and waterpump on it too..
Blaze '6 and Blaze D-turbo!
Yeah i meant i'd do everything you've said, plus HG if you havent seen the engine running and had a proper inspection of it.
All depend how far you want to go with it and how much money you want to spend on it. Would say cam belt, tensioners and water pump as a minimum as there a lot easier to do with the engine out
Engine running well, wanted to do most works as will be keeping car until it dies.
  Xud9 coolant pipes at rear of engine Donny165 1 5,329 17-05-2020, 08:48 PM
Last Post: Mighty306
  XUD9 Engine number location andy_diesel 3 5,734 18-11-2016, 07:44 PM
Last Post: bashbarnard
  Few engine related questions Danaidh 15 9,363 22-11-2015, 08:27 AM
