206 to 306 wheels
206 to 306 wheels
hi
will 206 wheels fit on 306
They'd fit offset is slightly higher tho so 5mm spacers may be needed, your other problem would be which wheels do you want to fit as they may or may not clear the brakes on your 306, also you may want to check tyre sizes to avoid scrubbing
should do. They are all 4x108. You may have problems with spacing though. What 206 wheels are they?
