4-2-1 exhaust manifolds
Just wondering if 4-2-1 manifolds fit easily in a 306, or whether there are difficulties with clearance to the subframe an bulkhead? If anyone has any experience of this I'd be interested to hear how people have got on.
You can buy them to fit, but they aren't cheap
As above. They're fairly expensive!
Ok, thanks for the advice I saw that maniflow do them for around £400, just thinking of options for the future. Good news that it'll fit though.
There are loads of types, The higher spec 4-2-1 with equal length pipes normally start around £550.00
Here's the stainless one I do
[Image: IMG_0995.jpg]
And during fitting
[Image: IMG_1523.jpg]
OK, so it looks quite tight, but no problems with it knocking against the car body work?
It'll actually be for an XSi 8v engine, if I go for it, so I'd have to get a 205 GTi manifold as it'll fit to the cylinder head, then will have to get a custom exhaust place to match it up to the system. It would be a pain for sure, but quite an interesting idea.
Completely different, I doubt the 205 one will fit as the iron block is taller and the bulkheads very different, Gain's on a 8v are not worth it unless very heavily modified, 170bhp plus
There was a chap on the forum several years ago called Joney who fitted a 4-2-1 from a 205 gti to a 306 8v, found this doing a search but he's not been around for years as far as I can tell, so I've got no way of finding out how he did it!
You could heat it up and bend it, It's like going the other way a 306 manifold doesn't fit a 205
Fair enough, sounds like it would be a load of faff so perhaps I'll just forget the idea!
  collecor manifolds.... brake-dust 2 2,426 22-09-2012, 12:45 PM
Last Post: samass
