Turbo oil feed
Turbo oil feed
Should there be a little rubber gromit/washer in the union nut on the block side of th turbo oil feed?
(27-01-2014, 02:40 PM)willJspears Wrote: Should there be a little rubber gromit/washer in the union nut on the block side of th turbo oil feed?
Don't believe so just tighten it up tight should be good, well that's what I think anyway
Well I've tightened it up as far as it will go, but got oil leaking from it,
Not where it screws in, but where the union but slots over the feed line
(27-01-2014, 05:43 PM)willJspears Wrote: Well I've tightened it up as far as it will go, but got oil leaking from it,
Not sure then maybe I'm wrong some one might come along say there should be a washer or something
yes, as standard there is a filter that slides inside the oil feed and had an outer lip on which acts as a seal. i removed the filter and used a o-ring instead
306 XUD9 gt2052s
306 hdi stage 2 (hdi tuning)
205 STDT -new project
Some do, some don't.
Often the little filter that slides in the end acts as the seal, but some engines I've seen don't have this and don't need it to seal. Had exactly the same issue on my engine back in the day.
yeah, well i had that little filter thing but it was shagged, got some o rings on the way now
I have just come across the filter in my turbo oil feed. It looks in good condition. Is it best to keep it or ditch it and use an O ring?
I guess its the same as XUDs, i ditched it on my XUD
  Twin turbo high pressure oil feed setup. 205dtub 17 7,195 23-02-2015, 07:47 PM
Last Post: 205dtub
  turbo oil feed pugtk 5 3,214 20-01-2015, 08:23 PM
Last Post: pugtk
  turbo oil feed thread? ozonehostile 18 12,399 27-05-2013, 02:51 PM
Last Post: ozonehostile
