Why is my ecu playing hard to get?
Iv bought a kwp2000+, managed to install all the drivers, after i run the software and identified the ecu giving me all its series numbers i then click the read button and it askes me where to save it, i select an empty folder in c: and it either wont read it wont save, it says waking ecu...... Then a few seconds later says "internal hardware error". Iv tried everything, just cant seam to get it to work. Really starting to give up now. Anyone had this problem before
I had this problem too bud,
Seller said they had a lot of bother with the kwp, returned mine with a small refund my way and got a galleto 1260 (~£12 new) which has done me since! Not a bit of bother out of it.
Yep, I had the same. Returned and bought mpps.
JP
One thing to try, reduce the read speed from fast to slow, see if it makes any difference
Tried that made no difference. Thing is all the ones i find are from china. Cant be arsed tho wait again for another. If it wasn't for me working all the time id of drove up to you jp!
  Replaced TPS but still playing up... pugdan95 6 942 03-10-2014, 05:16 PM
Last Post: DeeTurbo
