Whats this
Whats this
Iv got this on my dash after changing my seats i disconnected battery and that before hand
What it mean n how to get rid please
Sorry pick ay that good
Does the seats you put in have side air bags ?
Yes mate
then you havent plugged them in properly
Check the connectors as the are common for producing a bad connection over time.
Ok will check tommorow and update if they are in correct what is the next step mate
Then the side airbags in your new seats are knackered.
More than likely the plugs under the seat, mines on all the time along with the airbag one to, give them a wiggle and then the lights go out but come on again after a while or if someones in the seat behind and hits the wires...
Plugs under seats for definate!! Give em a wiggle!!
Thanks lol ill go n wiggle them now what if i spray bit of wd40?
Wd40 wont do nuffin
If youre going to spray them with something, use electrical cleaner.
Ok thanks but way put resistor on them
