05-01-2014, 12:15 PM
I've an engine on the ground and the box is stuck on the release bearing, all bolts are loose any ideas on how to get it unstuck?
xud box stuck on release bearing
05-01-2014, 12:24 PM
You need to remove the clutch arm if the shaft so it can turn as the thrust bearing is attached to the clutch
05-01-2014, 03:45 PM
does the pin on the arm push out or pull out?
05-01-2014, 03:58 PM
pull, you'll never push it out due to the casing...
if all else fails, just bend the arm.
05-01-2014, 04:09 PM
Or if your putting a new clutch on wedge a bar inbetween box n block and force it off lol
| Anyone got a clutch release arm lying around? | Chairchild | 6 | 4,180 |
04-01-2015, 10:14 PM Last Post: Chairchild |
| Clutch release bearing alignment. | Marcus1991 | 8 | 6,929 |
01-04-2013, 01:25 PM Last Post: Marcus1991 |
