Intermittent wipers not working.
So my intermittent wipers aren't working on my Gti I'm convinced its a relay not sure what relay it is all the things I've found are for phase 2 Gti but nothing on phase 1.
Bye Bye D-Turbo
Are they not auto on ph1 GTis? If so there is apparently a blue relay behind the fusebox. Was covered a few days ago on a similar thread.
The phase 1s aren't auto I keep getting lots of info on the auto wipers though Sad
Bye Bye D-Turbo
In that case look for the blue relay behind the fusebox. Smile
In what way are they not working?
Sorry I didn't explain what is happening well when I put on intermittent it just goes to the first speed and continuously wipes the screen and it won't park when I just flick the stalk.
Bye Bye D-Turbo
Sounds like the tracks and 'fingers' inside the motor are worn/dry.
A motor service may cure it
I might just change the motor for a spare one then this happened before but fixed itself.
Bye Bye D-Turbo
Wiper Relays, Purple ones! or The mech / motor it self!
it usually is the motors at fault but im afraid i have no idea about phase1s.
Il have a proper look at the weekend so is it definitely the blue relay behind the fuse board for the wipers?
Bye Bye D-Turbo
  Weird intermittent fault with front wipers on 306 Dturbo Gaz85 3 3,074 24-02-2015, 12:21 PM
Last Post: Toms306
Question Auto wipers not working cr00000w 6 5,436 08-01-2014, 10:10 PM
Last Post: JamesG
  wipers stopped working - front and rear shelhug 4 4,063 21-04-2013, 01:31 PM
Last Post: shelhug
