Does anyone know anything about KWP2000
I bought a new KWP2000 ecu read/write, to upgrade to a stage 2. Everytime i try to save the orignal map file it says 'waking up ecu' and the leds flash on the box, the after 5 seconds it says internal hardware error, then wont do anything, it reads the ecu infomation at the begining, im running on windows xp which is the best os to run it on.
Basically does anyone have any ideas as what to try next or better still could someone near me down load the map file so i can send it off to whippy. Im near cambridge btw.
Thanks in advance
Matt
Gonna move this to the DW10 section, you might get more interest there mate.
If all the drivers etc.. are installed correctly, the tool is probably f*cked, very common on eBay KWP's
I had the same, KWPs are junk.
I'd go with an MPPS personally. Every map I write for people, I would always recommend they use MPPS, it's what I use, it has backup facility in it and it works on Windows 7, properly Wink
JP
JP
A genuine KWP and you'd have no issues.. It's luck of the draw entirely, I've had my KWP for as long as I've had the HDi (4 years?!) and written/read 40+ maps with no issues
Most people use KWP clones - most of which either don't work straight away, or fail pretty quickly.
As you say though, there are some which never fail and just keep working! Smile
JP
JP
Thanks for you advise, I've given up with the KWP2000 and bought me a MPPS instead, so hopefully should have better luck!!
  FAO: Galletto/KWP2000/ELM327 Users Ruan 10 3,757 01-11-2014, 08:16 PM
Last Post: Razorback_Rob
  kwp2000 doin my head in Chris306 2 1,191 20-07-2014, 11:44 AM
Last Post: Chris306
  HDI engine fault codes - KWP2000? jackmiller30 6 3,804 31-03-2013, 08:49 PM
Last Post: Poodle
