I hate coal
I hate coal
Oh ok, must be intermittent then, odd... No, the maf should be able to compensate for changes like that, else you'd have coal every time we had a heatwave lol.
Have you done the maf earth mod on yours?
I did do the earth mod years ago but it made no difference so I put things back. I done it because of the TPS errors I was getting.
Did you know that you can only clear fault codes 50 times on our ECU's? I got to the max number and after that you can't clear the code. I had to replace my ECU in the end. This happened shortly after I did the mod.
