Phase1 '6 beam into phase2
Is a phase 1 gti6 rear beam a straight swap into a phase 2, 1.9td non abs drum set up apart from hand brake cables?
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
Yes....apart from one possible thing...
the brake pipes may need swapping too, depending on if the ph1 beam has a compensator or not and same for the ph2 car
yes....apart from you might need to swap the brake compansator over Smile
PS all you need to do is use the brake lines from yours really, just may need to remove the compensator from the ph1 beam
Sound. Remove or swap compensator?
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
both phase1 and 2 gti6 will have an identical compensator, only late phase3 doesn't have one due to EBD.
you will need that compensator, yours being small drum non abs will have pressure limiters integrated into the rear wheel cylinders.
should be a straight swap mate
