Bosch pump for 6 cylinder
Slightly off topic, whats the code for the bosch pump needed to convert a 325 to mechanical?
Saw this, could be of use to someone?
http://www.ebay.co.uk/itm/Injector-pump-..._89wt_1327
Local to me also if it does need posting
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Thats on inline pump no? Different to the VE... Then again, this isnt ve specific forum...
Above post is almost useless, except for getting my post count up. Yay Wink
That's a 6 cylinder NAD pump
As said, NAD pump so no boost compensator...
The one you want for a 325TDS is the one from a 324/524TD, which were never sold over here I don't think...
If you want to use an inline pump, you don't want a compensator, they're shite. But trust me there's no way you'll fit an inline on a tds.... They're HUGE.
if it fitted a straight six merc I'm sure you can make it fit a straight six bimmer...
:p
It should fit nicely onto some 6 cylinder diesel turbo audi/bmw/merc though surely!
(21-12-2013, 11:08 AM)welshpug Wrote: if it fitted a straight six merc I'm sure you can make it fit a straight six bimmer...
:p
You'd he amazed, they're stupidly long... Unless they were designed to have them, generally they don't fit!!
Also they're chain drive from the crankcase, no belts, and have no dynamic timing adjustment... And if they do its centrifugal and built into the drive sprocket...
And that'll have wanky 5.5mm elements I'll bet...
  Slack in bosch pump? dt_ 14 11,198 21-10-2020, 03:41 AM
Last Post: dt_
  Bosch pump help for newbie PugRy 2 4,308 05-01-2020, 09:09 PM
Last Post: jamie182
  Bosch pump fuel screw broken Forby 0 2,995 12-03-2019, 06:47 PM
Last Post: Forby
