peugeot planet 2000
so before i buy pp2000 on ebay, firstly i thought i would see if anyone on here sells copies of it?
would prefer to give the money to a fellow user rather than just some randomer
copy of the software or the hardware?
software. the cables i will be ordering in the next day or so
where are you getting the cables and interface box most times it comes with the software
i was going to get a kwp2000 and use the cable from that with pp2000
wont work!
kwp is a remapping box not a diag box it uses different protacols let alone different software to run it
That won't work, you need the actual PP2000 cable
pp2000 software uses the lexia hardware interface copys of both can be found on ebay shipped from china (clones) carefull though as there are good and bad clones available
fair enough. thank you. i thought i would have got away with just using the serial connection port. i will have a look for the complete kits now. thank you
  Dell D510 Windows XP Laptop for Peugeot Planet (Laptop/Software only) Tom85 10 5,706 07-07-2016, 07:58 AM
Last Post: Tom85
  Peugeot Planet 2000 & XP Laptop Whodafunk 5 3,614 25-06-2014, 09:03 AM
Last Post: deggerz
  Peugeot Planet 2000 and XP laptop Whodafunk 2 2,344 01-06-2014, 08:20 PM
Last Post: Whodafunk
