clutch replacement
clutch replacement
Hi guys so I'm currently saving to have my clutch done as the release bearing is rattling on mine and I want it done asap.
Apart from the clutch kit itself, is there anything else I should be changing at the same time? Clutch cable maybe?
Thanks
[Image: 20gh7o0.jpg]
gearbox oil
gearbox shaft seals
I'd definitely say clutch cable, just make sure to put some sort of lube down the cable first, should keep it nice and free for a bit longer
I've heard of some kinda bushes that make the pedal lighter? I find it almost impossible move off without a lot of throttle
that'd be your clutch needing replacing then! lol!
grease up the clutch arm bushes and put a nice new light clutch in with a smooth new cable and it will be sorted!
These http://www.ebay.co.uk/itm/306-Clutch-For...5d46128663
Can be a pain to get the arm off though to replace them.
Thanks guys this is what I need! Want to do it all cos the stiff clutch is doing my head in at the minute lol
  clutch replacement prices dan wiltshire 1 955 13-03-2013, 09:46 AM
Last Post: declantg
