Differences between alternators
The 205 is playing up with flat battery issues again and I expect the 190k alternator has had it. I've found an xu10 one in the garage which should fit, but can anyone tell me if there's any difference between the alternators on 306s and if that'll be ok on the 205
Afaik as long as it fits, drash on Smile
It's not like the 205 has a sensitive electrical system anyway.
check offset...
I went through 5 to find one to fit the xud
I do have a spare one but plan to keep it as I've already had to replace one myself!
Fairly certain mine was off a 205 GTi.
Always the 205 forum you could check on?
Ok cheers guys.
(12-12-2013, 08:54 AM)Piggy Wrote: check offset...
Meaning pulley alignment with the crank pulley?
yeah thats it
Gotcha, cheers fella.
  ph1 and ph2 engine loom connector differences jirupa 23 23,405 08-02-2021, 12:40 PM
Last Post: Mighty306
  alternators molly 0 1,491 29-04-2014, 06:19 PM
Last Post: molly
