Guide: Fitting Plasma dial face's
#31
cully Wrote:
Neil Wrote:Cully JUst Wondering why you wired it in to the headlight leveller?
the invertor that powers the dials wants 12v and the wires i picked up come on (12v) with the lights and dont dim with the panel dimer Wink
Ah fair enough!
what wires have you connectedd them to?
is it wired to the head light leveler?
Mowle5677 Wrote:is it wired to the head light leveler?
mine is connected to the headlight leveler plug (ph3 Hdi)
Red wire = 12+ light feed
Green/yell =0v/ground
[Image: DSCF5799.jpg]
i ripped my car apart till i found the part that looks like on here Smile
hi 2 things were you get plasma dials from and that black box that shows mpg what is that and were you get that from as well thanks
i bought the dials from ebay a user named "chromemanics" there web site is http://www.visual-performance.co.uk/#/306/4534291809
the black box is a scangauge II http://www.scangauge.com/
be warned it only works on the hdi not the petrol stuff Wink
Good guide
ive just bought some from member... they fail to light up. Is there something im missing... theyve been bench tested all the contacts look fine.
S2 HDi >click<
154bhp
280lbs/ft
did you also get the invertor box and the switch and brightnes adjuster that powers the dials?
all the black dial plugs plug into it
I did the kit looks just like yours. The switch is on and ive had a looks over the joins and connections visually. They seem fine but ive noticed the wire is thin.
S2 HDi >click<
154bhp
280lbs/ft
A contact had snapped.
its worth getting some ph2 needles or colouring the ph3 ones red with a waterproof felt tip. Does make a difference and the red glows through when the lights are on
brilliant guide by the way
S2 HDi >click<
154bhp
280lbs/ft
Not a fan of plasma's, sorry, they just don't do it for me..
Dont fit any to your car then Smile
Just for you doddy!!
Theres better kits out there for more money. Xtuners will make you a oem style set. There was a group buy... however not cheap. These are definately better than the standard dials imo ofc
S2 HDi >click<
154bhp
280lbs/ft
Mine are Xtuners ones and i love them! Not exactly OEM but not as bright and as in your face as the cheaper ones we did a group buy on.
[Image: IMG_1069_zpsd2a53ae1.jpg]
*faces
[Image: sigcopy-1.jpg]
the xtuners ones are gorgeous
where can I get some ph1 diesel dials from? can only find ph2/hdi ones
xtuners pal.... Wont be cheap but you'll get some sweet looking dials fo sure
S2 HDi >click<
154bhp
280lbs/ft
  Guide: Lynx Rotrex SuperCharger Fitting Guide Eeyore 0 1,474 18-03-2016, 11:34 AM
  Guide; GTi6 Spliter Fitting Dum-Dum 4 5,263 08-06-2015, 04:34 PM
Last Post: woody90
  GUIDE: Fitting Upper & Lower Strut Braces Eeyore 39 28,681 29-03-2015, 01:42 PM
Last Post: Rippthrough
