Front Fog Lights
Okay guys, I've changed the bulbs, in the front fogs, changed the fuse, checked there connected up, turned them on and the light on the dash says there on but they ain't........ Not even one of them it's a 1.4 8V Meridian, T Reg if that helps, I'm stuck.....
[Image: IMG_0035_zpsb229e35a.jpg]
If it's any help at all
Check the plug that go's to the back of the light as the wires brake inside the casing. I had this with mine so cut the block off. What would be handy tho is having a current reader.
That's one thing I don't have, I got a tonge I could use to see if it's a shocking thing to do? Lol, The car will be at mine tomorrow (Darlaston, not far from you) if you wanna come give it a little look over mate?
A tounge?
*facedesk*
(07-12-2013, 11:33 AM)Matt Wrote: A tounge?
*facedesk*
Yeah I was joking mate, lol
I had the same problem but mine was a dodgy relay in the fuse box so I would check that before cutting the block off
Did you ever get this sorted ? I've got a 99 Meridian and neither of my front fog lights work either - despite the light in the dash working.
I've checked the fuse which is fine, but where would I look for the relay if there is one ?
(01-06-2014, 10:23 AM)DavidA Wrote: Did you ever get this sorted ? I've got a 99 Meridian and neither of my front fog lights work either - despite the light in the dash working.
Like the guy above you said, change the relay, that's what I'm gonna do and hope it works, I think there's also a passenger fuse box as well, not sure, but all the relays on this 306 Phase 2 are getting replaced with new one's pretty soon, the light on the dashboard works on this one as well!
(07-12-2013, 10:11 PM)nttrucker Wrote: I had the same problem but mine was a dodgy relay in the fuse box so I would check that before cutting the block off
Where's the relay located mate?
  Instrument lights, dash lights not working boggs 3 4,642 26-01-2016, 09:34 PM
Last Post: DeeTurbo
  Odometer lights and clock lights inop bashbarnard 3 3,974 23-07-2014, 08:43 PM
Last Post: DarkInferno
  N/S Brake lights/Side Lights not working Grant 10 6,270 18-11-2013, 08:02 PM
Last Post: Grant
