HDi FMIC Top & Bottom Pipes
Acquired with my intercooler and is of no use to me
£35 Collected takes it away. Else add £7.50 for P&P (£42.50)
1 x Top Pipe (Has been drilled and tapped for a boost gauge take off - Plugged at the moment)
1 x Bottom 2.2 HDi "C5" lower boost pipe. (If used on a 306 HDi, you will need to get a 41mm 90* bend with a good leg length - so I am told)
1 x Length of rubber intercooler pipe (It's the part that runs down in-between the engine and airbox - piece been chopped off the end, but maybe of use)
[Image: null_zps3706da95.jpg]
[Image: null_zpsf5c28930.jpg]
[Image: null_zpsf157b6ff.jpg]
Will you split these?
(05-12-2013, 11:44 AM)mcglynn Wrote: Will you split these?
Want them to go as one, ideally.
Ill have the lower pipe if youll split Smile
Where in the shire are you?
[Image: sigcopy-1.jpg]
Exeter area.
In Exeter today, probably won't have time to get these though, should be passing again on the 27th though. I'll give you £25 collected?
Sold??
Still available
Yeah, sorry I didn't pick me up, had the journey from hell on the way home (took 7 hours to do 200 miles), so I didn't stop off. I'd consider having them posted, just need to check my bank balance.
  Breaking: Heater matrix , hdi parts, FMIC kit, boost pipes Paul_13 68 39,215 26-04-2017, 01:31 PM
Last Post: Paul_13
  Hdi Fmic stainless upgrade pipes HDi--Power 22 11,140 26-01-2016, 08:49 PM
Last Post: HDi--Power
  Wheels spacers, fmic pipes, bolts, alternator, shims, door card lots of stuff! HD-Aye! 29 15,355 10-12-2014, 06:54 PM
Last Post: HD-Aye!
