anyone got a full (16) set of flat seat bolts suitable for gti6 steels, that theyre willing to part for for less than the £30 id pay new off ebay?
thanks
thanks
Wanted: flat seat bolts for gti6 steels
thanks
27-11-2013, 10:53 PM
I thought they were just normal steel wheel bolts needed?!
27-11-2013, 10:54 PM
Got a set here for £20 delivered?
Piggy, the GTi spares use the flat bolts, as obviously you wernt expected to carry a second set of bolts around to use the spare. ![]()
27-11-2013, 10:56 PM
May have sorted some cyclone bolts off CK2 as I think these fit?
Apparently I can chisel the welded washers off but Id rather not take a chisel to anything as it may result in a damaged wheel or more likely hand
27-11-2013, 10:58 PM
is that what a 'set' of 'gti steels' is then?...just 4 spare wheels??
coz I had one and scrapped it...it had the flat bit but also had the flange for a standard steel wheel bolt Wishes for more power...
27-11-2013, 11:00 PM
27-11-2013, 11:17 PM
You heard right. They bits the flat seat bolts sit on are just a press fit into the standard tapered bolt holes. They knock out fine wit a good blow from a chisel.
| Gti6 leather/alcantera seat base | MCH | 2 | 2,484 |
19-07-2016, 07:13 PM Last Post: MCH |
| Wanted: Flat seated wheel bolts - URGENT! | WiNgNuTz | 13 | 7,341 |
21-01-2015, 05:45 PM Last Post: WiNgNuTz |
| hub centric spacers and flat seated bolts | thebluepearl | 0 | 1,464 |
05-10-2014, 03:17 PM Last Post: thebluepearl |
