Bosch pump
I've got a leak coming from the max fuel screw any idea what might be causing this?
There's an o ring on the end of the max fuel screw take the screw fully out and you will see it probably guessing if you replace that it will stop leaking.
^This
HDi Cabby Project Click
  Slack in bosch pump? dt_ 14 12,836 21-10-2020, 03:41 AM
Last Post: dt_
  Bosch pump help for newbie PugRy 2 4,703 05-01-2020, 09:09 PM
Last Post: jamie182
  Bosch pump fuel screw broken Forby 0 3,266 12-03-2019, 06:47 PM
Last Post: Forby
