22-11-2013, 10:56 AM
To begin with, I have done a lot of searching on the forum and other sites plus google and still none the wiser.
Was driving oine day, come out the following day and refused to start, it was showing P0335 crankshaft position sensor.
It cranks but won't fire.
Here is a list of everything we have tried so far.
New lift pump with separate 12v feed.
Replaced Crankshaft position sensor
Replace Camshaft position sensor
Fitted several new 0 and 4 gauge earths
Checked cam has not slipped a tooth
Checked fuel rail
Checked injectors
checked all sensors
checked all fuses internal and external
Checked relay module (Behind ECU)
checked fuel cut off switch
checked third piston cut off
swapped battery terminal clamps
fully charged battery and jumped off three different cars
tried bumping
applied easy start which fired briefly then cut out and wouldn't start again
unplugged fuel pressure sensor to test if pressure related
tested glow plugs as pointless as this was
This is a small list of actions taken. Everything tested with multi-meter seems to be at the correct values as specified by Autodata.
What am I missing?
Any help appreciated as at the moment I am completely puzzled.
Checked fuel rail
Checked injectors
checked all sensors
tried bumping
What am I missing?
