306 hdi not starting ***please read***
To begin with, I have done a lot of searching on the forum and other sites plus google and still none the wiser.
Was driving oine day, come out the following day and refused to start, it was showing P0335 crankshaft position sensor.
It cranks but won't fire.
Here is a list of everything we have tried so far.
New lift pump with separate 12v feed.
Replaced Crankshaft position sensor
Replace Camshaft position sensor
Fitted several new 0 and 4 gauge earths
Checked cam has not slipped a tooth
Checked fuel rail
Checked injectors
checked all sensors
checked all fuses internal and external
Checked relay module (Behind ECU)
checked fuel cut off switch
checked third piston cut off
swapped battery terminal clamps
fully charged battery and jumped off three different cars
tried bumping
applied easy start which fired briefly then cut out and wouldn't start again
unplugged fuel pressure sensor to test if pressure related
tested glow plugs as pointless as this was
This is a small list of actions taken. Everything tested with multi-meter seems to be at the correct values as specified by Autodata.
What am I missing?
Any help appreciated as at the moment I am completely puzzled.
broken wire from the cam sensor to the ECU?
check wires for continuity in the engine loom also check the plug at the chassis leg where the engine loom plugs into the chassis loom
Just swapping the Cam sensor plug for a spare and checked most now and all fine so far I'll check plug now cheers
could it be an immobiliser issue?
Sounds like Immob - you need to get proper PP diagnostics on it - that'll tell you the actual issue rather than throwing parts at it.
Ive read that if it were immobiliser it wouldnt show anything on the code reader and I'm getting a sync with the ecu and I know this but haven't got pp2000 and as I'm breaking the car don't see the point it buying it
If you're breaking the car, why are you fixing it..?
As Cully says, if its still showing crankshaft codes after replacing the sensor you want to be checking for continuity.
Have you checked live data when cracking to see if it's picking up all the right signals on the code reader
Checked cars lines throughout and all have continuity liturally down to glow plugs and don't have live data mate
Had this same problem with mine changed in tank pump to discover yhe fuel pump solenoid on the right hand side of fuel pump was gubbed so replaced that and its firing no bother only problem i have with mine now is its in limp mode witch is pointing to a fuel pressure sensor
Sounds like a problem I had a while ago, was immobiliser. I'd check that out.
(27-11-2013, 05:02 PM)craig306hdi Wrote: Had this same problem with mine changed in tank pump to discover yhe fuel pump solenoid on the right hand side of fuel pump was gubbed so replaced that and its firing no bother only problem i have with mine now is its in limp mode witch is pointing to a fuel pressure sensor
Limp mode doesn't necessarily mean it's the pressure sensor at fault, just means the engine is running on a reduced range to avoid possible damage from the fault.
