Heater Blower intermittent (Ph3/HDi)
Hi guys,
have the fan messing me about at this time of the year. Headache. Sometimes while driving along it will operate as normal, others it will faff about and go slow, changing to and fro on its own accord.
Is there any fix to this or is it a fault in the controls panel or even the motor itself?
I remember on the mg it had resistors but this isnt a 1,2,3,4 system so im not sure about it.
Thanks in advance.
nobody got any info on this? Sad
Check the connector out . Mine did this and had been arcing when not quite plugged in properly.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
which connector am i looking for buddy? one on the motor itself?
On the blower motor itself. I had recently had mine out to oil the bearings.
ah, just had a nosey, seemed to be in ok but gave it a wiggle and tried the blowers, working dead on!
must have been a loose connection, i need to get the motor ut of mine and grease the bearings too, sod is squeaking crazy
Problems again Sad had it all out l, greased and back in, works fine but sometimes it doesn't come on then randomly flicks on
Meh, it will still be the connector. Mine did this for a while but then sorted itself out. Smile
Its really stiff going into the connections? The switch looks like it has to open to take it out? Im assuming thats the correct way as that's how I done it.
Otherwise its not playing ball very well lol. Pain in the ass.
It seems the blowers don't change position too, I dont hear a motor open or close the flaps or move anything to redirect the air?
  Heater blower issues Dturbo john 5 5,861 13-03-2018, 01:53 PM
Last Post: Toms306
  Heater Blower Issues MY95 7 7,737 06-03-2018, 11:22 AM
Last Post: Magenta Sunset
  Heater blower problem Pingaz 7 5,467 04-06-2016, 01:19 PM
Last Post: Pingaz
