Will a 14" fan fit with a 12" fan on standard rad.
Or is 2 12's the max. Anyone actually fitted some and not just guessing?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
I thought even 2 12's didn't fit. You could only get 2 10's?
I fitted 2 12" slim line fans to mine. I cant see a 12" and a 14" fitting though as there wasn't much spare room with 2 12"
Im not sure if ph1 rads are much difference in size to a ph2/3
Phase 2/3 is smaller due to not having the "header tank" attached to the side of it. Not sure if it makes a difference to actual core size though!
