Heaters issue
I'm having this really annoying problem with my heaters where it will blow warm for a short while almost as if the matrix is getting a really restricted flow and will eventually cool down after about 30 seconds of warm air.
It will blow warm again eventually but it's pretty crap in this weather. There's no leaks and both of the matrix pipes are hot.
Any ideas?
Stage 2 XUD Sedan
Tried bleeding the rad? Had a similar problem when mine had a small airlock before the matrix started leaking
Thats what mine did, time for a new matrix
Yeah I bled it a few times now and it's getting circulation which is what confuses me
Stage 2 XUD Sedan
im also having this problem and i have no ide what to do anyone help me? drop me a pm ifso many thanks
Its partially blocked. Blowers blows over it and it cools it down because theres bugger all heat going into it.
I removed the pipes from the firewall and put a pressure washers in both pipes from the matrix, it helped but did not fix it. if you have lots of time its easy job to change it
Yeah its just fooked / choked.
A temp fix take hoses off and flush it in reverse flow with a garden hose, but if its super f*cked / rotted you may wreck it totally, but ive done this before to flush out shit / makes a suprising difference t oflow / heat!
Just remember not to remove this grommet from the firewall, just slice along the red line, makes refitting 10x easier. Some guides also say to split the matrix and leave the pipes in the grommet but i would not recommend that either
[img][Image: DSC01817_zps113f26a4.jpg][/img]
  Heaters popping fuses. kentiiboii 3 2,445 16-10-2014, 05:25 PM
Last Post: kentiiboii
  Heaters Matt 8 4,675 08-03-2012, 11:25 PM
Last Post: Daniel306
