Threads: 34
8
Given 8 thank(s) in 8 post(s)
There is no lift pump in a XUD. There will more than likely be an air lock now, does the grenade get hard once pumped up?
Threads: 8
Car Model/Spec: ph1 Dturbo
Given 0 thank(s) in 0 post(s)
Yeh it gets hard once pumped
Threads: 87
48
Car Model/Spec: Rouge vallelunga 5 door Dturbo
Given 74 thank(s) in 70 post(s)
yeah sounds like you're getting air in somewhere
Threads: 195
6
Car Model/Spec: 2000 Xs 1.8 16v
Try the bleed nipple on the fuel housing.
Threads: 8
I will check the bleed nipple when i get home and i will also check the grub screw on the side of the filter housing aswell just incase Thanx guys
Threads: 34
8
If your on about the white 1 dont touch that lol
Threads: 87
48
(18-11-2013, 01:38 PM)Seb_Ryan Wrote: If your on about the white 1 dont touch that lol
that's probably where it's leaking from though tbh . .
Threads: 8
Ok it dose look a bit britle to be honest so I won't touch that one
Threads: 8
So i checked the bleed nipple when i got home and everything is all tight!!
The grenade had emptied the diesel out again so i pumped it up till it was hard only when i let go i could hear a very faint noise like air was being sucked in!!!
Threads: 122
9
Car Model/Spec: Kingfisher Ph1 Dturbo S
Given 7 thank(s) in 7 post(s)
There will be an air leak somewhere most probably the fuel filter housing
Threads: 8
I think the Grenade has had it so i have ordered a new on and some new Fuel hose aswell.
Lets see if that sorts it. it sounded like the air was being pulled in through the grenade so i susspect a little pin hole or something
