306 hard to start letting diesel run back?
have a 306 d turbo here sometimes its very hard to start heater plugs are spot on i have a feeling it could be letting diesel run back to the tank would i have to change the filter head or the hand primer or whats the best fix ?
(11-11-2013, 02:04 PM)john85cw Wrote: have a 306 d turbo here sometimes its very hard to start heater plugs are spot on i have a feeling it could be letting diesel run back to the tank would i have to change the filter head or the hand primer or whats the best fix ?
whatever is knackered lol . . . could be a few things, squeeze the primer til hard then squash it hard and hold it to see if there's any fuel/air leaks . . . .Smile
Hand primer is a couple of quid to change.
Could be the seal around the fuel filter housing, take it apart clean it with brake cleaner and goo it back together with silicone - again a couple of quid.
Could be leak off pipes - again a couple of quid to change.
All things considered you might have to spend upto a tenner Smile
Could be a blocked fuel filter also, ontop of whats been said above.
Thumbs Down Hard to start Owen_G_ 17 8,129 27-02-2015, 06:56 PM
Last Post: Owen_G_
  Diesel back box Aaron _d95 8 7,113 06-05-2013, 11:38 AM
Last Post: Aaron _d95
  air in fuel hard to start when cold dec-66 12 6,804 07-11-2012, 12:42 AM
Last Post: Kwik
