Group N linkages, XUD starter, spacers, XUD bits
Used Miles' Group N gear linkages, nice tight gear change, no play £20 posted
406 coupé auto dim rear view mirror, plenty of wire to connect to courtesy light £25 posted
25mm hubcentric bolt-to-hub spacers, 4x108 65.1mm centre bore direct Peugeot fitment, come wth nuts and bolts, everything needed to fit £35 posted
Red slam panel, wire bushed, primed and painted, tiny rust marks but overall good condition £30 posted
Delphi fuel pump primer grenade, good working order £10 posted
XUD starter motor, good condition, strong crank £25 posted
XUD top hose £10 posted
[attachment=11463]
Fuel filter and thermostat housing, no leaks, comes with thermostat housing £15 posted
[attachment=11464]
XUD heater matrix hoses £20 posted
Xsara mist washer jets (correct ones for 306) £5 posted
Plenty more bits available, ask if you need anything
Phase 1 Rad please.
and brake master cylinder.
So very tempted by the spacers!
Go on mate, will do them for £30 posted as i'm feeling nice today Wink
First post updated
What's the I.D. on the wheel side of the spacers? Wondering if I could machine them down to fit something else.
[Image: sigcopy-1.jpg]
65.1mm buddy, same centre bore as standard Pug wheels
**edit wait, the inner diameter? 60mm-ish, no accurate way of measuring i'm afraid
Yeah, the inner, so I can machine the outer lip to make them centre bore adapters.
Using a ruler and playing it safe i'm rounding up and saying 60mm inner diameter
Hmmm, not really small enough, interesting.
Rad fitted today seems to be of excellent quality and was along with the Master cylinder packed superb.
  Wheel spacers and bits bashbarnard 2 2,514 17-03-2015, 05:57 PM
Last Post: bashbarnard
  Uprated gear linkages Chris 4 2,897 25-02-2015, 11:44 PM
Last Post: 306Dan
  FOR SALE: Blue carpet, baker bm gear linkages. kentiiboii 11 6,611 06-08-2014, 09:51 PM
Last Post: DazzaHDI
