04-11-2013, 06:28 PM
Evening all after the above for my old s16 must be free ɑnd not leaking! What ya got??????
Rear compensator ph1 s16 urgent
05-11-2013, 10:23 AM
What's peoples thoughts on bypassing this??
Considering ιts a track car with gti fronts, ιts not as if the rear ιs ever going to have load! Does ιt need a load compensator??
05-11-2013, 11:40 AM
(05-11-2013, 10:23 AM)Jonny b Wrote: What's peoples thoughts on bypassing this?? Probably be surprised with the effects that has.. I'd probably go for the fixing it option.
On the 306 waiting list.
05-11-2013, 11:43 AM
(05-11-2013, 11:40 AM)Jake Wrote:(05-11-2013, 10:23 AM)Jonny b Wrote: What's peoples thoughts on bypassing this?? this ^^^^ i wouldn't do it again lol
05-11-2013, 01:06 PM
How are the s16 valves any different to any other phase 1?
Phaes 1 GTI 6 - Onyx Black
05-11-2013, 01:15 PM
(05-11-2013, 01:06 PM)ginge191 Wrote: How are the s16 valves any different to any other phase 1? I think all the compensator valve are the same on ph1s and maybe all the 306s. Im not sure if disc and drum axles maybe different though (05-11-2013, 10:23 AM)Jonny b Wrote: What's peoples thoughts on bypassing this?? The axle on my d turbo doesn't have a compensator valve but my S16 does. Im not sure why some axles do have the valves and others dont
05-11-2013, 01:28 PM
Well iv had ph3 gti axels on ph2 without the compensater and it was fine.
Frost, ph3 beams dont have then as the load is compensated by the ABS system instead, hence why some axels dont have it |
rear brake compensator | hycraig | 0 | 2,311 |
26-03-2019, 07:57 PM Last Post: hycraig |
| Wanted: Brake compensator bits. | Jonny81191 | 12 | 5,213 |
17-09-2015, 07:55 PM Last Post: Jonny81191 |
| Wanted: URGENT! Rear pads and brake line | Nathan1305 | 8 | 4,621 |
01-09-2014, 06:17 PM Last Post: Nathan1305 |
