lucas pump stop solenoid replacement
Got my stop solenoid removed from my lucas pump, but my new one looks totally different to my old one, any ideas
new one - http://s1038.photobucket.com/user/willJs...9488405161
old one - http://s1038.photobucket.com/user/willJs...7546886662
is the black shroud thing on the old one, part of the tamper proof setup?
(01-11-2013, 01:12 PM)willJspears Wrote: is the black shroud thing on the old one, part of the tamper proof setup?
looks that way.
screw the new one in, find your 12v ignition feed (mostly red wire on the pump plug), put a ring connection on the end and connect it onto the top of the solenoid.
job jobbed. Smile
yeah, its all sorted now, ive had to run a wire from the battery, so i can put a switch in or else the car will just keep running without the ignition on, was a bit of a faff but got there in the end
Wire it from the reverse sensor or something that's ignition live
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Hi,
Bumping an old thread where did you get your new one from?
Thanks
i got it off ebay, ill try and find the link for you
http://www.ebay.co.uk/itm/PEUGEOT-306-Di...5d3e91099f
Its ok the local motor factors had a replacement! Didnt think they would!
Thanks tho!
okay bud. have you got to the old solenoid yet?
  Lucas pump cap carlukepeugeot 7 9,153 19-11-2020, 12:14 PM
Last Post: johnny625
  Lucas pump timing probe issues weka 0 2,920 21-03-2019, 08:39 PM
Last Post: weka
  No power to Diesel stop solenoid Olly 306 1 2,752 14-01-2019, 01:17 PM
Last Post: Mighty306
